MF Weights on a D17 AC |
Post Reply |
frnkeore
Silver Level Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
Posted: 01 Jun 2019 at 7:24pm |
I bought a pair of 28" MF, PA wheels and tires, about 6 months before I got my D17. After I got the tractor, I did some measuring and found the bolt pattern to be the same for the wheel weights. Of course you can't put them behind the wheels but, to me, they don't look to bad, this way.
Over the last 6 months, I took the weights off the MF wheels (400 lb each, with bolts), cleaned them up and added some new paint. Then, I did some measuring and ordered some 3/4" bolts, 1" longer, than I figured I'd need, for 2 reasons 1st, If I had mis-measured, I could shorten but, not make them longer 2nd, I also, have 2 sets of 150 lb weights, that I can add coupling nuts and add them on the out side, giving ~1100 lb total. It makes the tractor 16" wider (94"), as is, maybe 8" more, if I add the 150's so, I'm not sure I'll do that, unless I need to make a class. Edited by frnkeore - 02 Jun 2019 at 10:35am |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
bradley6874
Orange Level Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
How close are they to going inside I found my new l180 had 8 bolt spacers 1 1/2 thick in between the hub and rim
frnkeore
There is no way that they could ever go inside on a D17 center. The contour, just isn't close and there is not much room between the hub and the final drives. The MF center has a much deeper dish.
Edited by frnkeore - 01 Jun 2019 at 10:28pm |
Frank
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8330 |
Frank,
Looks like they found a new home. You headed for the 6,000 lb class? Regards, Chris
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2955 |
Striking terror into every fence post in the area (LOL)
frnkeore
Chris,
Yes, at least the 6000 class Gotta weight it and see where to go. Gary, I got hooked on the pictures in the Nebraska tests |
Frank
Post Reply | |
