oil in a 1983 5030 allis 2 cyl diesel
Thomas-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomas-NC Quote  Post ReplyReply Direct Link To This Post Topic: oil in a 1983 5030 allis 2 cyl diesel
    Posted: 24 May 2019 at 3:06pm
Manual calls for straight 30 wt and says not to use multi grade oil.  Will 15-40 Rotella work
Edited by Thomas-NC - 24 May 2019 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 3:55pm
I can't imagine how an engine would know it had multi weight oil in it.......... 15-40 is an EXCELLENT diesel motor oil.    15 will get easy starts and fast oil pressure buildup in the winter, and 40wt is a good oil for southern US states in summer.
Edited by steve(ill) - 24 May 2019 at 3:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 5:57pm
Don't forget to drain and replace the oil, in the injector pump, occasionally!  IIRR, it has its own oil reservoir, with its own oil plug...Wink
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2019 at 3:12pm
15-40 is all I've used in my 5020 in the last 10 years
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomas-NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 6:57am
Thanks for the help and tips.  Much appreciated!!
ChrisS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 1:09pm
I guess if Eric hasn't had any issues in 10 years than the injection pump doesn't care about using a multi-weight oil either. I have been trying to change all my diesel engines over to Rotella 15w-40 and just have one oil on the place.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 2:12pm
the pump won't care! put 15W40 in it, it'll be just fine.
