912 H Making into Hydro Lift
Doug Acord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug Acord Quote  Post ReplyReply Direct Link To This Post Topic: 912 H Making into Hydro Lift
    Posted: 10 May 2019 at 8:21am
I Have a 912 H that is manual Lift now. I Have a 7117 simplicity roller with all the hydro lift parts. I know I need the spring and valve out of the 7117 pump. I also know I need everything that was attached to the hydro lift on the tractor. Is there any reason why this swap should not work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 10:16pm
Good question. I'm woundering same thing
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 4:32pm
It will work. Just put hydro lift on My 914 with electric lift. We had to change the rockshaft the lift handle on because the hyd cylinder is bigger than the electric cylinder. Soak your lift handle where it mounts on the shaft so it will slide off easy.Good luck. Hydraulic lift is so much easier for me than the toggle switch on the electric lift and a lot easier on the batter
