S 16 New Holland / Arens
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: S 16 New Holland / Arens
    Posted: 09 May 2019 at 10:59am
I need the drive sheave that fits onto the PTO on back of tractor . Origional uas a coupling splined inside and a double belt pulley that was welded to that - in the end abolt holds it onto the PTO .
 Seems daughter in law borrowed tractor - rand it and link pin cam out and she kept running it until that drive unit was junk -
 Well I was going to weld on new pulleys but somehow I set it in a save spot so it would not get lost --- Have not found that spot again !
 It is about a 4" diameter 2 belt unit - uses a 3/8" x 1 1/2" bolt to hold unit onto PTO shaft . Arens bought the New Holland line of lawn equipment and most things interchange
