170 front pump drive hub
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 170 front pump drive hub
    Posted: 08 May 2019 at 1:01pm
Does anyone know where I can get new hubs that bolt to the front crankshaft pulley to drive the hyd pump? The bolts are not evenly spaced so the ferd drive hubs wont work. Does anyone reproduce them? Once the splines wear out what does one do?
www.awtractor.com
A&W TRACTOR 920-598-1287
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 1:18pm
The parts bok says it should be the same as my D17 crank pulley.  I've got a post on the Knowledge base about the Ford drive coupler that fits.  Unless someone else has messed up your hub, it should be the same from the D17 through the 170.
AaronSEIA
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 1:20pm
is it for loader pump drive is it gas or diesel
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 2:03pm
One of the vendors in the Old Allis News has some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 3:06pm
countryside tractor has the parts or a kit 717-923-0421
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 8:51pm
Alex, I make a hub and new shaft. Not exactly like original, but it won't wear out like the factory ones do. Tracy
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 11:07am
A local machine shop bored out the hub and pressed in a sleeve with original matching splines.  Cost two years ago was less than $150.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 1:24pm
have new hub, shaft, sprocket and chain for both the gas and diesel 507-766-0551 Steve
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 1:33pm
I welded a new splined end on mine and then it also reached the unworn splines on the shaft. female end must not have been a close enough match as it only lasted about 40 hours....Agco had the parts at that time, but wanted over $800 for the parts!
ALLIS EXPRESS!
This year:
This page was generated in 0.172 seconds.
