D17 diesel starter? problems
n17cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel starter? problems
    Posted: 25 Apr 2019 at 11:04am
Hello folks,
I have a d17 and its diesel, not sure of year.
Ran fine, has 12 volt system, alternator hasnt worked for a while.
now wont start, just a hard click when I turn the key to on, but nothing when I attempt to start it.
it has 2 solenoids mounted just front of the battery shelf.
Any suggestions on how to trouble shoot this thing would be greatly appreciated.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 11:12am
Check the volts at the starter when trying start engine.
Dusty
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 11:19am
I solenoid is for the intake air heating element and the other would be for the starter. Dusty has a good test, also check the volts at the battery while attempting to start. Also, see if the engine will roll over by hand just for the H3!! of it........
1968 D15D,1962 D19D
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 11:44am
You said the alternator has not worked in a while. Fix it, charge your battery and the tractor will start. A drained battery will make the solenoid click but not turn the starter.
Edited by DSeries4 - 25 Apr 2019 at 11:46am
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 12:28pm
check and make sure engine isn't locked up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 1:05pm
it has a fully charged battery 13.6 volts
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 1:07pm
it appears to be the solenoid... 12.8 on battery side 8.6 on starter side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 4:57pm
Check all the cable/wire joints, it could just be a bad, loose and/or corroded joint/connection.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 5:49pm
I put a new solenoid on it and had the exact same experience
So i pulled the starter and found the bendix stuck in the forward position
will attempt  an internal clean-up and let you guys know how things worked out,
side note Ill be changing all of the connections and replacing any questionable wires or cables.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 6:28pm
8.6 should be enough to turn the starter. What is the battery voltage while you are attempting to crank the engine?
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 12:57pm
take jumper cables to starter ground on starter body and hot on starter where battery connects to starter if it tries to start work your way back
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 12:55pm
The Battery may have 13.6 standing volts, but to make sure its supplying enough power in the crank mode, you need to do a draw test on the Battery to make sure its good.  Do a draw test. If the Battery is good, check & clean your connections. Wouldn't be a bad idea if you took the Starter motor to the local rebuilder and let him run some tests on the unit to make sure that's okay also...  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 5:28pm
The starter was just dirty... internally after a good cleaning and shining my tractor is running again... thanks for the help Gents
Edited by n17cattle - 27 Apr 2019 at 5:29pm
This page was generated in 0.289 seconds.
