CA pin hitch draw bar
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Topic: CA pin hitch draw bar
    Posted: 21 Apr 2019 at 9:43am
Put the draw bar on the CA yesterday as per the manual for the first time since I've had it.
Where it pins on underneath, is there supposed to be a bushing of some sort between the pin and clevis? I ask because it's real sloppy and seems like there should be.
Thanks.
Jared
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 10:13am
None shown as a separate part in the parts book. The written description says clevis with bushing; for the clevis (Item 29) at the pin end of the drawbar. Someone might have a part number for the bushing. You might be able to have the clevis bored to true it up if it needs it and the bushing is gone. Then have a bushing made to fit.
CA_Pin_Hitch_Drawbar.pdf
Edited by Jim.ME - 21 Apr 2019 at 10:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 10:33am
Thanks, Jim! Thought there should be one there.
Ill look tomorrow at work to see what would work. Tons of bushings available. If something isn't quiet right it'll be a good government job for the machinist :)
Jared
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 11:27am
TedJ gave me a pin hitch drawbar this winter, here is a picture. I can clean it up and measure it tonight, if you'd like.
The mechanic always wins.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 7:26pm
Odds are you are missing the spacer tube in marks picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 8:14pm
Yup, missing that. Measurements would be great! Thanks :)
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 8:53pm
Got it cleaned up. I originally thought it was brass, but now that I got the grease off it, it is steel. Its a little oblong, she's obviously pulled a few implements in her day.
3" long.
7/8" I.D
1 3/8" O.D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 10:54pm
Glad to be of use! LOL
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 7:16am
That's funny Ted. LOL
And more knowledge shared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 10:27am
Awesome! Thanks a ton
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:38am
Draw bar ain't sloppy any more :) Thanks again for the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 11:33am
So did you find one, or make one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 12:29pm
The machinists at work did one up for me:)
