My machinist cut the fire ring groove too deep
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: My machinist cut the fire ring groove too deep
    Posted: 05 Apr 2019 at 10:15pm
My machinist cut the groove for the fire ring in the sleeves .058" deep and blue print said .030-.032" deep for .105 fire rings.  So I have no crush on my fire ring. any band aid ideas or are 6 new liners  headed to the scrap bin ?
Edited by Beirnesy - 05 Apr 2019 at 10:53pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 6:20am
Did he have the blueprints?  Sounds like he owes you 6 new liners.  Or fire rings that will work.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 6:37am
Yes he had blueprint that FVP sent with the fire rings.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 6:53am
I had this same thing happen years ago. I was told to use sleeves shims under the fire ring to take up the room. It worked I believe there are 2 thickness and one was still available. An old allis dearer would know or Doc
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2019 at 10:10am
Cant you use thicker fire rings? Seal Tech makes any size.
