B cold vale clearence
2011dandd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Topic: B cold vale clearence
    Posted: 16 Mar 2019 at 5:07am
Hi
I want to check the valve gap/clearence next week on the b.
Does anyone have a cold gap that’s correct?
Also will the rule of nine work for this engine?
Cheers
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 5:20am
Tappet clearance .010" Hot from manual Gerald posted. .012" to .013" cold will be a good starting point. Rule of nine should work.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
brkfldj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 6:30am
Educate me, please. What is the rule of 9?
Thanks.
Jim
Democracy is two wolves and a lamb voting on what is for lunch. Liberty is a well-armed lamb contesting the vote. ——— Ben Franklin
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 7:04am
This covers the older Allis Chalmers data.
If you have to ask questions on how to set the valve gap you would be well served to do one cylinder at a time. Short cuts followed will get you there but will not help you learn all the details in how to trouble shoot some problems.
One cylinder at a time both rocker arms on the cylinder will be all the way up and to be exact the flywheel will have the TDC mark in the center of the inspection hole. It is not necessary to check the exact top dead center on these slow rpm engines but is a way for a person to double check.
I learned to set the valve gap in the 1950,s with the engine running at idle. A few oil spots on the face and shirt sleeves was part of being a mechanic.
I set these engines at .012 both hot or cold. What happens with having them a little wider within reason is a noisy valve train. Setting them tighter than the .010 can result in burnt valves or a miss firing.
Edited by Dick L - 16 Mar 2019 at 7:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 7:34am
I had to look it up when he asked. Apparently it is commonly used with 4 cylinder sports cars. It maybe slightly more accurate than using the rock method. Like Dick L, I learned to check and set valve lash with the engine running, other than for the initial setting during a rebuild or head/valve work, which I usually did using the rock method.
Valves_Rule_of_Nines.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 6:10am
Thanks for the help.
Watched a few videos on how to do it whilst the engine is running.
Is that an accurate way of doing it?
Please correct me if I’m wrong but is that a case of
Backing the nut of slowly until it starts to make a taping noise
Then tighten but up just enough for the obvious tapping noise to stop
Then 1/2 to 3/4 further turn on the nut.
Job done??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 7:41am
The nut is a lock nut not an adjustment nut. You put a 5/8" box end wrench on the nut and a screw driver in the center. You unlock the screw and adjust with the screw driver. When running at idle I tighten the screw on a .012 feeler gauge until I hear a miss and then loosen it until the miss is gone. That is the way I did it until about 20 years ago. I then started setting them at TDC on each cylinder. It is less messy and just as good. On these small low rpm engines a couple a thousands wide will not make a difference in performance. Tight can though.
Double checking is not a weakness. It is called being prudent!
Edited by Dick L - 19 Mar 2019 at 7:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 10:03am
2011dandd,
It sounds like you watched a video(s) of adjusting hydraulic tappets (lifters) in an automobile. Your engine has solid tappets and that procedure does not apply.
Here is the instruction section on adjusting the valve tappets from the Allis Chalmers D14 Operator's manual that may help you. Use the clearance spec for your engine in place of the one in this document. As Dick L said use a wrench to unlock the nut, turn the screw with a screwdriver to adjust, then set the locknut to hold it. You will likely need to hold the screw with the screwdriver while you set the nut to keep it from turning and changing the adjustment. Check it again after you have the wrench and screwdriver off it to see that it stayed where you set it.
Valve_tappet_adjustment.pdf
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 11:53am
Thank you Dick L and Mr. Bonney. Thumbs Up
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 12:10pm
Originally posted by Jim.ME Jim.ME wrote:
Tappet clearance .010" Hot from manual Gerald posted. .012" to .013" cold will be a good starting point...
Just do this and call it good.
1951 B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 9:56pm
Valve clearance in an overhead valve engine can be a bit critical. Needs to be enough clearance that the valve closes completely when the engine is hot and the heat has stretched the length of the valve stem, bent the rocker, stretched the length of the push rod, and expanded the length of the block and the height of the cylinder head. All those pieces changing dimensions due to heat makes forecasting a suitable cold clearance likely to be wrong. If the valve doesn't close all the way it will burn the valve and the seat. If the clearance is excessive, the valve won't open as much and will restrict the air flow in the intake valve and the exhaust flow out the exhaust valve hurting engine performance.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 5:44am
As always thanks for the advice and all the know how. Invaluable
Cheers
