Some 7060 questions
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Some 7060 questions
    Posted: 14 Mar 2019 at 6:57pm
Just finished rebuilding my 426 in my 7060 and got some questions regarding it, first is I think my coolant Gage is off, the temp rises quickly hits 230 but using an infrared temperature gun it says the top rad hose and engine block are around 160 degrees Fahrenheit,plus feeling it by hand it definitely does not feel 230, now I just recently replaced the sending unit along with the rebuild, so could it be the gauge in the dash itself? Fuel Gage seems correct, if it is will a Gage unit out of a 8000 series work? Like the way it looks better, seems easier to read etc, second question is do I need to do a retorqued of the head after I run it in?
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 8:07pm
PUT A CAP TUBE/MANUAL GAUGE IN IT AND SEE WHAT TEMP YOU COME UP WITH, WAS THE RAD RE-WORKED?
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 8:27pm
You didn't use teflon plumbers tape to seal the new sending unit did you? to get proper gauge readings the sending unit body needs a good contact to "ground" in order to get a proper reading. Teflon plumbers tape can interfere with making a proper ground. By the way the factory used 180* F engine thermostats in the 1970's.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 9:10pm
Are the sending unit and gauge matched. Not all sending units are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 9:21pm
No tape used, metal to metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 9:22pm
Agco sending unit, same as the old one I pulled out.
