190 parking brake latch problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 parking brake latch problem
    Posted: 29 Jul 2010 at 6:26pm
I was messing with my 1964  190 AC the other day and the parking brake latch is giving me a fit ; when you flip it back and step on the brake for it to release , it wont release , it just gets tighter, if you flip it back + forth a few times it may work and may not ; it seemed to have some play on the shaft , so I shimmed it , didnt help, its really aggrivating , anyone have this happen ?
Gordon,scia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordon,scia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 6:59pm
We had a similar thing happen to our One-Ninety.  Turned out that one of the hydraulic lines was interfering with the linkage.  We replaced that line with a new one that had a ninety degree fitting (or something like that, IIRC) and it corrected the problem.  Look up under the hood at the back and see if anything is in the way of the lock mechanism.  Hope this helps!
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 7:48pm
      If the latch is in wrong it will act that way.
                                           John C
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 8:36pm
Is the roll pin that holds the lever on the shaft broke?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 7:37am
Lube/oil the rectangular block that fits on the shaft....they get dry and sticky.
