Series 1 d17 hydraulic pan
sstevens1985 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sstevens1985 Quote  Post ReplyReply Direct Link To This Post Topic: Series 1 d17 hydraulic pan
    Posted: 22 Feb 2019 at 11:25am
Any thoughts on how the linkage finger for traction booster will go past that plunger? When I put my traction lever to the bottom of the quadrant it binds against that plunger causing my lift arms to stay raised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 5:41pm
Theres a lot of fresh cut steel in that picture, is something worn bad enough to slip?Wink
Take a look at this thread...
Edited by DiyDave - 22 Feb 2019 at 5:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sstevens1985 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 8:02pm
What is the purpose of that metal cap? It appears worn out and in bad shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sstevens1985 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 9:32pm
I cannot tell much from pictures, but most likely place is cam roller worn out and maybe cam lobe.      MACK.
