Need to get the 7G lit off
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Need to get the 7G lit off
    Posted: 09 Feb 2019 at 2:21pm
Had a smallish white oak come down ON the back fence, Loads of widow makers so need to get my old gal lit up and drag some out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 2:23pm
Was not away from it fifteen minutes and this one shifted
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 6:22pm
DMiller,
    Why the V  cut on the downed log in the one picture with your saw setting by the cut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2019 at 8:22am
So I could get a 24" bar through it without pinch. Used that technique a lot in my younger days, kick a small wedge out to allow deeper cut and less tree to bring back out of when have less ability to get at the underside. Nice square edge to set steel wedges to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 5:12pm
Well NO tractor today, ice storm yesterday, a Royal PITA then rain from early hours all thru the day today, may be march before dry enough to get back in there.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 3:00am
Too soggy here as well
HD3
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 1:52pm
Same conditions in Michigan. Freezing rain for Monday and Tuesday with 8 inches of blowing snow and 19 degrees in Michigan. I hate not being able to do any serious work on any of the equipment due to cold and wind.
Bobcat needs seals replaced on control valve. Need decent weather as you have to work without gloves.
Oliver needs all fluids changed and that is best done when a little nicer out.
HD16 Im itching to power wash and steam everything off to get started working on some priming and painting but too damn cold.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 2:38pm
Froze tight last night so dragged batteries down and old Allis busted right off, a nice warm up and off to the back easy on solid ground. Got the bigger junk out of the way just as the Greasy started to set in, tried to drag out the log but too slick just got it out of the way and went to setting fence repairs. Managed to get all patched back in and trundled back to the barn put everything away for the storm coming Fri-Sun. 3-6" snow predicted.
This page was generated in 0.179 seconds.
