7000 torque tube question
jeremyroff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeremyroff Quote  Post ReplyReply Direct Link To This Post Topic: 7000 torque tube question
    Posted: 06 Feb 2019 at 7:58pm
Does anyone know how much wider and heavier the 7000 torque tube is than the 190 tube?   And does it have more clutch room? Looking to install profab or Atlas trans inside it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 7:21am
It is longer front to rear in the area of the triple clutch pack. Diameter is about the same as the clutch discs are the same p/n. How much weight?? I have no idea. Not a lot. Less than 200 lbs for sure on a bare housing. A 7000 torque tube does NOT bolt up to a 190/200 rear end as it is. Get a split gasket and you'll see what I mean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeremyroff Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 8:04am
Thanks Man... thats what I was wondering... My son wants to start building a tractor and I figured we should try to do all the improvements and upgrades that didn't get done on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 9:30am
What weight classes and HP level are you going to be in for a Pro-Fab transmission ??
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 2:24pm
Seen the SCS 3 speed gear boxes in the 180-190 housing. I talked to the owner of the one I seen and a tube chassis is recommended. The housing is cut up pretty good. Everything but the rearend is dry
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeremyroff Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2019 at 8:11pm
Not much... Eventualy would like to see what mine has or maybe a little more. LLSS
This page was generated in 0.095 seconds.
