Woods question
Baxter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baxter Quote  Post ReplyReply Direct Link To This Post Topic: Woods question
    Posted: 31 Jan 2019 at 11:34am
Hello everyone. I'm new here. I now with woods mowers mounted on C Allis for many years now. An L306 and 59. I have a friend with a b and was wondering if woods makes the lower tube for the narrower b for the L 306.The telescopic tubes for the no. 59 mower that I have are all for reight turn blades.The b is newer so it has dish wheels so can be set out.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 2:51pm
Go to the wood web site and check
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 3:02pm
Baxter,
Welcome! We need some pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 3:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baxter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 4:43pm
Hello again. It is 30 degrees below zero here. The tractor is a simple B with hydraulic that works. 1953 so a C engine. I have worked with L306, 59 and L59 mowers but have never seen the mounting tube for a B for a left turn mower because they are solid where my 59 tube is telescopic so I think would work on either tractor but is for right turn blades. Thank you all for your help.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 5:21pm
The adjustable (telescopic) will work for both. It is how you thread the belt on the mower that makes the difference between the right or left hand cut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 5:28pm
Yep, its just a twist, one way or the other...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 9:33pm
What Dick said. I had the 3 piece push bar on a Woods and could run it either way. You can go buy a new single piece bar and it will have the exact same configuration of the idler pulleys as the 3 piece bar.
 You route the belt different, to get right or left rotation of the spindles.
Edited by CTuckerNWIL - 31 Jan 2019 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baxter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2019 at 4:59am
Thank you everyone for your help. I am new here and already am having a great experience. You guys rock!
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2019 at 8:59am
I have a Woods tube painted P.O.#1 with no pulleys I'd like to get it out from under my feet. One piece tube.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baxter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2019 at 9:44am
Hi Mike. Thank you for the post. Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 8:43am
South central Missouri.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baxter Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 10:28am
Probably not cost effective for me to try to get it. Thank you for posting.
