C question
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Topic: C question
    Posted: 26 Jul 2010 at 5:33pm
Can the 5 bolt hubs on a C be used on B finals, and is there any reason not to use the large wheel center as an outside weight on another C?
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:00pm
Only if it is the style hub with the splined center below. The 5 bolt C hub/shaft are a different configuration than the B splined shaft, and won't fit in a B final drive. I believe the C shaft is a little longer.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:10pm
Given what Larry B Fan said, if you have access to a machine shop anything can be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:17pm
Thanks, what would that splined hub be from? Did some model C's use them?
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:23pm
The small splined hub above was used on some B's (most frequently B's with the staight front axle, for some reason) They're not rare, but not common, either.
Edited by GBACBFan - 26 Jul 2010 at 7:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:24pm
B's had a splined shaft and the wheel center fit the spline. Some later ones had the 5 bolt hubs to fit the shaft.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 9:43pm
From left to right: B spline axle (most common on B), B 5 lug axle and C 5 lug axle. The early adjustable front axle B's where sometimes equipped with the spline to lug adapters shown above prior to development of the B lugged axle.
As  you can see, the C and B axles are not interchangeable.
Edited by Brad MI - 26 Jul 2010 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 5:04am
Thanks, pictures explain it all.
1C 1 WD45 1 AC180
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 11:36am
If this makes any sense Chuck. The bolt pattern on a 5 lug B flanged axle or the B splined hub adapter is the same as a C.  The wheel centers are different. Wheels for both the B with the flanged axle and the C are reversable deep dished and have the same AC part number. The B wheel center for the B with the adapter hub is reversable and has a shallow dish. Almost flat.
      I guess you could use C wheel hubs for wheel weights. They just don't stack up to neat to bolt them on. Find yourself a set of the thicker 4 notch C wheels like used on Cs on steel and use them without weights to add weight.
      All Cs used only the short flanged axle
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 11:23am
I have used extra C wheel centers as wheel weights on a C, would work on a B with the the 5 bolt hubs as well. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 1:55pm
Thanks Kip, I have another C with inner weights and thought about hanging spare centers on the outside.
1C 1 WD45 1 AC180
This page was generated in 0.081 seconds.
