What's it worth |
Dek Thorne
Joined: 19 Jun 2015 Location: Pennsylvania Points: 114 |
Topic: What's it worthPosted: 13 Jan 2019 at 1:44pm |
What would a freshly rebuilt ca engine be worth
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24774 |
Posted: 13 Jan 2019 at 1:56pm |
a loaded question ! 'rebuilt' ..to what end ? All new sleeves,bearing,dist,carb,??? what was replaced..main bearings back to factory spec ? 'should' be worth 3X parts installed value, maybe.. a LOT depends on whether buyer NEEDS it If it can be heard running...$1000 ?? Jay
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 13 Jan 2019 at 2:34pm |
I am in the process of doing a B engine (for my steel wheeled, war time B) right now, so I can give you some figures.
My prices: Sleeve, piston & ring kit - $380 Complete gasket set - $60 Valve train kit - $110 Rod bearings - $65 Main bearings - $100 Shims (rods & mains) $50 There was also some shipping costs on most parts. My crankshaft (out of a combine engine) miked out perfect with standard bearings, so I had no machining on it. I don't have a price on just the machine work, since I sent a D-17 head at the same time, but I had the block, head and D-17 head hot tanked, the block decked, head and manifold resurfaced and new valve train installed with new seats, plus the work on the D-17 head and total machine work was $550. I got all my parts from Jim Danforth at OK Tractor, except the valve assembly and sleeves, pistons and rings that I already had . My guess is somewhere in the range of $1100, but again, my crankshaft didn't need machining, which saved me some money.
Edited by WF owner - 13 Jan 2019 at 2:37pm |
WF owner
Posted: 13 Jan 2019 at 2:36pm |
That's why I grabbed a C for $600, that was pretty rough, but the engine ran like a top.
