8010 powershift
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: 8010 powershift
    Posted: 08 Jan 2019 at 6:10pm
Thoughts on a 8010 powershift with 4500 hrs on it 2wd under $10000.
Are the 8010s a solid tractor?
Whats a good loader to put on one? Preferably a allis loader.
Also how big of a deal is it to put on a joystick? It only has 2 remotes.
Thanks in advance
185 turbocharged w/ 500 loader , WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:00pm
Always heard the 301 was a pooch in them without some extra fuel and air,, good looking tractors tho
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:05pm
Heard the same thing. Get a 8030 instead.
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 8:33pm
Have 2 of them one fwa, one two wheel both power shift lots of hours very reliable, easy on fuel.
Both set at 115 hp. If you need more hp buy a larger tractor. Sounds like a good deal, not a very good loader tractor.
Edited by K bockting - 08 Jan 2019 at 8:35pm
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 9:09pm
I also have 2 of them-FWA has well over 6000 hours without any problems (has the 16 speed tranny.) The motor in the 2 wheel drive was overhauled before I bought it and I don't remember what the hour meter reads but they are both good dependable tractors IMHO. The power shift in the 2 wheeler is decent but don't know if I would care to put a loader on either one of them. Never thought the 8010 was a pooch-used to pull 4-18 plow, 20 foot disc, and 22 foot field cult., in heavy black ground-now have bigger horse for that!
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 9:12pm
Need pictures-but if that one looks and runs good- 10,000 is a good price.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 5:57am
That’s a good price if it’s in any shape. I have an 8010 and I love it. I pull a kinze 8-15 with it, 15’ batwing and the baler. Couldn’t ask for a better more comfortable tractor for those jobs. Also have an 8050 and 8070 for primary tillage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:01am
It is clean and interior is nice. It is cold blooded though.
It will mainly be used on the baler.
Just curious about a loader for it? Any suggestions on that ?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:09am
We bought a power shift 2wd 8010 last spring. We hooked it up to the 750 gallon Hardi sprayer and haven't unhooked since. Much faster road gear than the 200 for getting from farm to farm. We wouldn't be without it now. It's not real difficult to add a 3rd remote, I added one to our 8050.
Leon B Mo
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 9:07am
Have a 8010 with 20 speed pd tranny. Love it. 7800 hours on original motor. Im second owner and bale hay with it. Love cabs. I always say there like having a 2 ton truck with a small block motor. They get job done. I have a great bend loader on mine also
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:14am
Not sure why anyone would say an 8010 is a pooch, it's essentially the same tractor as a 7010! Now one with FWA may not be a ball of fire lol!
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 6:19pm
I have an 8050 PD 2wd with a westendorf WL-61 with a joystick I would sell. Located in Indiana
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:02pm
Compared to a 7000, the 8010 + 7010 are heavy tanks.
They're good on dry or frozen ground but don't take them onto a soft wet spot or you'll sink out of site! Add a loader with a round bale and a set of 250 lb weights on the rears and you'll want to put bigger tires on the front.   It will dig itself a hole.    And guess what a cattle pen looks like when it rains?
Been there done that...as long as you have a backup tractor for the wet/slippery conditions you can make it work.
Can you afford/tolerate having two loader tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:11pm
Abunch of weight difference there on the 7000 to the 8010, and same engine
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:06pm
  The talk about an 8010 being a dog probably came from someone that had one with an AMBAC 100 pump,  the small cubic inch 301 with the sloppy governor of a 100 pump makes for a gutless feel to it.    Earlier 8010s had DM4 Roosa Master pump and ran well just like 7010.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 11:28pm
Lot of tractor for the money.  We use an 8010 FWD to pull a 12 row planter or a NH big round baler, or to pull a Hardi sprayer.  It does those jobs very well and is easy on fuel.  Not quite as easy on fuel as a 6080, but the 8010 weighs twice as much.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 11:15am
I don’t think you would be disappointed. Easy on fuel. Mine starts well. I have mine with an intercooler set at 128 hp. It’s a toss up if it’s any better or worse than my 8030 8050 or 8070. Lol
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
