200 series trailer disc
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Topic: 200 series trailer disc
    Posted: 07 Jan 2019 at 12:07pm
I've got a 214 Allis wheel disc that I picked up a few years ago. A few of the Bal-Pak bearings have seen better days. I've heard they're obsolete, what can I replace them with? Also, one gang of disc blades are smaller than the rest, how do they come apart so I can put the correct sized blades on?
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 12:57pm
ball-pak bearings are available used from several places....seen them a swap meets...take one of yours off to make a match....or rebuild??
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 1:27pm
You can look in the Knowledge Base section on this sight for a good description of parts and how to on these bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 4:07pm
I'll have to look around for them when I get into restoring my implements. Still have plenty of work to do on the tractors haha. There might be a shop in town that I could get new ones at.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 8:54am
The bearings are really an assembly and no longer available.
I wrote the knowledgebase article. Take a look at it. Sure you can pay $50-$100 for a used bearing, but I'd rather have  a new one.
To take a gang apart, First remove the hanger bracket bolts and drop the gang and brackets off the disk.
Next take the gang axle nut off the shaft then slide the pieces off one by one. Carefully lay them so you can put them back exactly how they were. The bearings and spacers are directional so you have to put them back on correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 6:09pm
And, like doing brakes on a car, if you only take one side apart, at a time, you always have a pattern to look at(the other side), should there be any questions on how to re-assemble...Wink
