Odd Allis WF tractor
Matt06br View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt06br Quote  Post ReplyReply Direct Link To This Post Topic: Odd Allis WF tractor
    Posted: 03 Jan 2019 at 9:50pm
I recently purchased an Allis WF.   The front sheet metal is styled but the rear fenders are the unstyled type. The tractor has electric start.   Seriel number is 2232.   From what I read in an Allis book, one is pictured in this variation but none where produced for sale.
I purchased this tractor from it's second owner.   He stated that this tractor was bought brand new in the Door county Wisconsin area.   The tractor was used in a cherry and apple orchard for the first part of it's life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt06br Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 9:55pm
Also, second question.   Is it possible to take the radiator, sheet metal, and misc from a doner unstyled WC to make this look like an unstyled wf? Has anyone attempted a conversion like this? Thanks
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 6:26am
Interesting, There is a picture of one in Norm's book taken at the factory, Who told you one like it wasn't sold?  I would leave it the way it is and restore, will be a real conversation piece at shows.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:12am
Obviously at least one was sold!
May have been an attempt at an ‘Orchard’ WF.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:24am
im no wf expert and checking the serial number to dertermine the year would shed a little light, but i think it is completely within the realm of possibility that the original customer had the dealer install unstyled fenders on a styled tractor to keep low hanging branches out of the tire like other orchard tractors.
Edited by CAL(KS) - 04 Jan 2019 at 7:25am
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:04am
I agree with Mark. Yes the hood tank and radiator will change but I believe I'd leave it as is. You have the most valuable pieces, rear fenders. Now you need to get a unstyled and a styled to show with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:43am
Interesting thing is I have a 1939 salesmans binder and the literature is styled for a WC and unstyled for a WF. I guess it took them a little longer to get the fenders design complete. I do think it is possible your WF was sent that way from the factory considering the year of mfg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:47am
A lot of these are in Canada so when those guys thaw out I hope there is more opinions. Calvin may have some info on this topic.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 9:10am
It's obviously an early WF, since it has the slanted exhaust manifold.
It all looks like a styled except the rear fenders and the angle iron frame under the seat and the seat base (suspension). I have never seen a seat base like that on a WF unless it was an option?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 9:40am
Cool looking ,but as we all know a lot of years passed and any one could have changed anything with parts they had. Any type of story from owner before .
nonetheless ,still dead.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 10:07am
Is there a hole in the hood for an exhaust pipe?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 10:09am
Could be a "Built from a combination of the 10 parts tractors sitting here" I've done a few  those.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 10:25am
Can we see pictures of the right side of it and more of the seat? There was a curved iron that filled in between the fender and frame on the unstyled. Who knows, maybe it is a 1 of 1.
Edited by Unit3 - 04 Jan 2019 at 10:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:12am
The curved filler pcs are not in the picture but they would not be there because the side panels under the unstyled tank are not there either. Who knows,farmer Joe may have been in a hurry to get one and did get it in the transition. What was on the front? Blade?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:43am
The steering gear is the early Lavine which was used on WF's up to #1903, the last of the unstyled models.  Styled models, #1904 and on, used a Ross gear which had a different steering wheel with a smaller hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt06br Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt06br Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:50am
This tractor did have a snow blade attached on the front.   When looking at the rear fenders, everything looks like it was done right, there is no farmer welding or modifications.   The second owner had it for approximately 35 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 12:53pm
Correct me if I’m wrong, but wasn’t the side exhaust used on distillate tractors; even styled versions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:22pm
Well I don't care what you say, that battery box doesn't look factory. Is there a hole in the hood for the exhaust pipe? I don't think I have ever seen a styled hood without one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt06br Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:52pm
There is no hole in the hood for exhaust.   I have a 39 styled wc with no hole in hood as well
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:26pm
I posted an odd allis on here once and got the same response as you have. If its not in the "bible" it didn't happen. I don't see it that way. From looking at the pictures I would say that was done at the factory. I don't feel it is up to the owner to prove that it was, it's up to the skeptics to prove it wasn't. Could have came out of Canada, Allis was known to ship things that did not sell well in the U,S, up there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 2:12am
The seat is aftermarket. It was made by Knoedler. Looks like it has styled brake covers on it.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 5:32am
 Everything has a STORY  and everyone has their opinions about that story .
   Sold new dose not mean it came from the factory in all cases .U have a neat looking tractor with a neat story that came with .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 5:57am
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:20am
allisrutledge, I am not a WF expert even though they were once very common in this area. Next door neighbor had 3 WF's . I'm guessing that the dealer likely changed the fenders and possibly the exhaust manifold before it was delivered new at the customers request. Norm Swinford told me personally that it was very common in California for dealers to modify an new tractor to the customers needs.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:46am
Example of dealer changes.
I don't think that any WD's came with Snap Couplers. My dad bought one of the last WDs, he was the first owner, the dealer had used it as a demonstrator. It had the Snap Coupler on it when we got it.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:02am
I know we are getting off subject, but we rarely see a WD without snap coupler in our area. I think a lot depended on how the dealer ordered them.
I never knew it was possible to buy a 180 or 190 without a hydraulic PTO until I started in this forum. Our local dealers ordered all of them (that I know of) with hydraulic PTO.
WF's were quite uncommon in our area. My grandfather bought his new in 49. We have a lot of relatives in Canada and he had seen a new WF when visiting. It was narrower and shorter than a WC, which he liked because it would fit in the barn, so they could shovel manure directly into the manure spreader, so he requested one from the local dealer. To order a WF, the dealer had to order 2. They were the only 2 WF's in northern NY that I ever saw.
He didn't get a PTO because his Ford 9N had one and it had a side mounted mower, which was the only PTO thing he had.
Edited by WF owner - 05 Jan 2019 at 9:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:48am
I bought a WF from a guy around Courtland NY back in the early 1980's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:51am
On the snap coupler subject. No WD's left the factory with snap coupler and it wasn't until approx 4800 WD-45''s had been built that SC became standard equipment. Most WD's including my Dad's was retrofitted with a SC.
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 10:23am
In looking at pictures the plate around the clutch pedal is from the later styled wfs and the fender brackets are from later styled wfs and serial no is a later styled wf my guess is they wanted the unstyled fenders for some reason and swapped them in still a nice find
