1952 Model D Grader
Wild Bill 2 u View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Bill 2 u Quote  Post ReplyReply Direct Link To This Post Topic: 1952 Model D Grader
    Posted: 21 Dec 2018 at 9:24am
Anyone have parts for one of these?
If anyone wants or needs a propane conversion for a D get back at me, I have one I will trade or sell...........It can be found here https://1952acmodeld.tumblr.com
Thanks
Edited by Wild Bill 2 u - 26 Dec 2018 at 10:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 8:46pm
You're at the right place, welcome to the forum.  What parts do you need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Bill 2 u Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 9:18pm
I am looking for either specs (working dimensions so I can fab one) on a scarifier, or a scarifier. I need also need the ram that goes with it as well. Thanks Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Bill 2 u Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 10:52pm
I am also looking for soft cab parts?
wn willis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wn willis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 2:10pm
D grader 1952 Ser # D 1547.  Has a Zenith Carb I have not been able to identify. Numbers on small round tag as follows: 22825,  directly opposite, 115?8. The question mark is because I cannot determine the number. It appears to be a 6 but not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 6:33pm
Carb should be same as wd/wd 45 ag tractor uses. I have the scarifier, on mine, but its too damn cold right now to measure it up for you.  You might wanna get yourself a manual, for it, I know Jensales sells 'em, they are a poor excuse for a manual (poor copy re-print), but easy to find there. Once you have a manual, its easy to see the measurements you will need.  Its not a full width scarifier, basically about 3-3/12" wide, 6-7 shanks, suitable for ripping up the center weedy section of a 2 track road...Wink
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:18pm
The 8 in the 22825 doesn't look quite the same as the 8 in the other number. Could the number be a 6? Could the number you can't make out be an 8?
226257 would match to a Zenith carb with a production number of 11588, used on AC's, according to a list on Norfar's industrial carb website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wn willis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 9:40am
You have solved my problem in identifying the carb. Much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wn willis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 1:30pm
Finally uncovered the moter ser#. 45-55237-G
Post Options Post Options   Thanks (0) Thanks(0)   Quote wn willis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 1:32pm
Now to identify correct carburetorfor that motor.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 3:34pm
Tsx 464 should be a correct Marvel Schebler carb for that motor.  dont know on the zenith
Post Options Post Options   Thanks (0) Thanks(0)   Quote wn willis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 3:56pm
That sounds good. Thank uou.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2019 at 7:10pm
My 51 D only has the ram and valve/hoses. no scar. on it. would also like to make one. thanks; ac fleet
P.S. Tumblr has lost it! LOL!!! they did the same to me over there! Don't know why they turned into such asses!
This page was generated in 0.313 seconds.
