WC Unstyled 12Bolt Head |
| Author | ||
shaverjeff
Topic: WC Unstyled 12Bolt HeadPosted: 08 Dec 2018 at 10:45am |
I'm having trouble locating a replacement gasket for an early style (12bolt) head. So far everything I can find through the usual suspects is 15 bolt only. Does any one know of a source for these earlier style head gaskets? Thanks in advance.
| Sponsored Links | ||
Alvin M
Posted: 08 Dec 2018 at 1:19pm |
Reliance special order
MACK
Posted: 08 Dec 2018 at 9:01pm |
Why not use the 15 bolt gasket? MACK
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 08 Dec 2018 at 10:05pm |
15 bolt should do just fine. AaronSEIA
shaverjeff
Posted: 09 Dec 2018 at 5:50pm |
I had the same idea, I ordered a 15 bolt, but they are different.
The water jacket holes didn't line up quite right and they were really small.
shaverjeff
Posted: 09 Dec 2018 at 5:58pm |
The water jackets towards the bottom are completely different and the extra boltholes line up with the bigger coolant openings on the bottom.
Edited by shaverjeff - 09 Dec 2018 at 5:59pm |
shaverjeff
Posted: 09 Dec 2018 at 6:08pm |
MACK
Posted: 09 Dec 2018 at 9:55pm |
Turn it end for end. Have put a lot of late gaskets on that old block with no problem. Block serial was #49. MACK
shaverjeff
Posted: 10 Dec 2018 at 7:02am |
Turning it end for end doesn't make a difference, the head/block is symmetric.
Perhaps I have an oddball block/head or more likely my 15bolt gasket is for something else? No matter how I install it, I'm literally almost plugging two of the 3 water jackets. The extra 3/8" bolt holes in the gasket encroach on the larger water hole. ![]() |
shaverjeff
Apologies for poor quality pics:
shaverjeff
Posted: 10 Dec 2018 at 3:35pm |
Still trying to track down a replacement.
Reliance does list a kit on their site, but I called to confirm and they no longer offer them. Walt's tractors lists a 12bolt, just waiting on a confirmation. |
DrAllis
Posted: 10 Dec 2018 at 3:47pm |
If you are concerned about the small holes in the newer version gasket, don't be. There are hundreds of thousands of WC-WF-WD-WD45-D17-170-175's running out there with THAT GASKET !! The small water hole goes towards the radiator.
AaronSEIA
Posted: 10 Dec 2018 at 4:08pm |
If those holes are your only issue, just punch them out a bit bigger. I'm with the Dr. That gasket is under thousands of functioning heads and I have never once heard of overheating a head due to it.
AaronSEIA |
shaverjeff
Posted: 11 Dec 2018 at 7:32am |
Thanks for the replies. My biggest concern was the difference in water hole size but also it looks like the additional 3/8" unused bolt holes line up with the water jackets...I guess that shouldnt matter though as its no different than the unused holes on the opposite side of the head. The thickness was quite a bit different also .08 for the old and .06 for the new.
I had initially put the gasket on and torqued everything down and it seeped from both sides as I filled the radiator. Likely an oversight on my part for not coating it with anything. I've read several different methods from silver paint (the original had this) shellac, copper coat, and I think "hylomar". I'll give it another go before I pay out the nose for another gasket. Thanks again.
DrAllis
Posted: 11 Dec 2018 at 7:41am |
No sealer of any kind on one of those gaskets will result in coolant seepage.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 11 Dec 2018 at 8:27am |
The new gasket does not appear to be metal on both sides with gasket material between? Been a long time since I worked on one but the old gaskets used to be metal on each side with the progressively smaller water jacket holes to the front and when you had ether the 12 bolt heads or even the early 15 bolt head with the three 3/8" head bolts (vs 7/16" later--- D17?) on the one side, we would take packaging string and put a strand between the metal all along the one side on heads with no head bolts and even the 3/8" bolts. This would seal those heads up nicely. That was at least what the older mechanics at the dealership I had worked at did. But no good if new gaskets are not metal on each side. |
Wink I am a Russian Bot |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35675 |
Posted: 11 Dec 2018 at 8:45am |
For these style head gaskets to preclude weeping or seeping we used Copper Coat gasket sealant on Both side for correcting any small surface irregularities on head or block, also used same compound on solid head gaskets for flathead engines LIBERALLY to keep them sealed up.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 11 Dec 2018 at 4:55pm |
Throw that flimsy black gasket in the trash and get a Victor Reinz 3162, as pictured below on my WD engine. BTW the progressively smaller coolant holes are an updated design and serve to cool the head more evenly by restricting coolant flow towards the front of the head, perfectly normal. Copper coat sealant on both sides unless you have block and head planed, then absolutely no sealant. ![]() Edited by Bill_MN - 11 Dec 2018 at 4:59pm |
shaverjeff
Posted: 12 Dec 2018 at 7:01am |
Bill_MN thanks for the part number. The quality difference is drastic.
I've placed my order and hopefully I'll have this buttoned back up for christmas.
shaverjeff
Posted: 17 Dec 2018 at 6:38am |
![]() Ordered the part number listed and this is what I got. As far as I can tell mahle distributes the victors gaskets but this is what I got...looks like a step above my previous gasket but still not thick and metal on both sides like the original. I coated both sides with copper coat, took my time, and this one started seeping as soon as I started filling the coolant. It was better than the first but still leaky. I might have to bite the bullet and kick this thing to the machine shop, or the scrap yard.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 18 Dec 2018 at 5:49pm |
Jeff, I sent you a PM>
shaverjeff
Posted: 26 Dec 2018 at 12:16pm |
Thanks Phil.
I tried the new gasket coated in coppercoat and it suffered the same fate. Seeping as soon as I filled the radiator. There's some pitting on the head at the water jackets that I think was letting the water in. I took some JB weld and filled all pitting carefully, then coated (very thinly) the head/block in the blue stuff (like hylomar but permatex brand). Weird sticky stuff indeed, but a thin coat filled the scratches on the block....I think the block scratches are actually grooves from years past machining but they seem questionably deep. Coated the first gasket in coppercoat and torqued everything down. This seemed to do the trick at least for now. I still need to get a new set of points and seal up the oil pan but its moving under its own power again, for the first time in a decade or so. |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 26 Dec 2018 at 2:18pm |
Looks like all that's out there is that head gasket, I called my AGCO dealer just now had him put the gasket has Fe-lPro on the gasket and looks just like yours. I have three more NOS gaskets left and they will be used on my jobs so they are not for-sale, sorry.
Edited by Don(MO) - 26 Dec 2018 at 2:19pm |
Bill_MN
Posted: 26 Dec 2018 at 2:22pm |
Hmm, that's a bummer. I did my WD engine about 4 years ago, they must have discontinued the "good" gaskets, but why?? I agree you may have to have some machining done.
Don(MO)
Posted: 26 Dec 2018 at 4:15pm |
Edited by Don(MO) - 26 Dec 2018 at 9:15pm |
Alberta Phil
Posted: 26 Dec 2018 at 4:21pm |
Just a word of advice here, Jeff. When you're cranking any tractor like that, your thumb should be under the crank handle the same as your fingers. If it ever kicks back with your thumb in the position you have it in your video, you'll end up with a broken or dislocated thumb or maybe worse. Just be safe!
Bill_MN
Posted: 26 Dec 2018 at 6:04pm |
Interestingly enough Don, the overhaul kit I got at the time from Tony (I believe it was Howard brand) had the same cheap gasket in it as well. I was not satisfied with it so I ordered the Victor gasket and got the good one. I cannot remember where I ordered it from though-may have been old stock even back then.
Edited by Bill_MN - 26 Dec 2018 at 6:05pm |
Don(MO)
Posted: 26 Dec 2018 at 9:19pm |
timstoybox
Joined: 27 Dec 2018 Location: St.Charles,mn Points: 1 |
Posted: 27 Dec 2018 at 6:28am |
I to am having trouble with the wc head gasket, rebuilt but the water runs right through the head gasket. Appears the head gasket bearly covers the water jacket hole ?
