AC WD expansion plug
Wyattstoll89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wyattstoll89 Quote  Post ReplyReply Direct Link To This Post Topic: AC WD expansion plug
    Posted: 25 Nov 2018 at 12:37am
I have a wd , one of the expansion plugs in the head was rusted threw and letting coolant by. I replaced the plug by just tapping a new one in.I started the tractor today after being down for a couple months to find water was seaping in around the plug. Was i sapost to put any sealent around the plug? What is the exact size is the plug? What sealent should i use ? I also installed a new radiator today and noticed a brown substace bubbling out of where the headgasket is ? Any help would be much appreciated!
Edited by Wyattstoll89 - 25 Nov 2018 at 12:42am
DWC17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DWC17 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 1:55am
Any of the steel plugs that I installed, I always put Permatex around the plug then tapped it in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wyattstoll89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 1:54pm
The one i bought from o reileys, didnt have a lip like the other one had so i dont know if that matters?
Sorry i had to edit , was half alseep
Edited by Wyattstoll89 - 25 Nov 2018 at 3:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 8:21pm
I always put red loctit on a plug.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2018 at 2:13pm
You have to have the rim/lip on the plug.That's where it seals.Dad always smeared Permatex #2 on them.
Edited by SteveM C/IL - 26 Nov 2018 at 2:15pm
This page was generated in 0.107 seconds.
