Time For Bearings Ina Mower
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Time For Bearings Ina Mower
    Posted: 22 Jul 2010 at 8:44pm
Time for bearings in my Woods L59 mower under my one B. While at it I let things get out of hand.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 8:58pm
nice work is that a yanmar in the back ground ?
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 7:41am
That be a Simplicity 95-23 or same as a 5020. I had at one time started to make it look like an Oliver.  I put Allis Chalmers C cast centers on it a coupla years ago so I am not sure what to call it.
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 12:46pm
What size of bearings are they? I will need to do that with mine in a year or so. Is it hydraulic lift? If so can you send me a picture of the "v" shaped piece that attached to the cylinder/frame.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 12:56pm
Boomer, I see a manual lift handle so I'd say it ain't hydraulic lift.
mojo/Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 4:33pm
Boomer, you can get bearings here at a fair price. You can look at the parts drawings as well.
Click on the spindle assembly line at the left. Prices are then on the right.
http://www.messicks.com/Woods/1122.aspx
Edited by Dick L - 23 Jul 2010 at 4:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 6:02pm
This might be the part you are wanting a picture of Boomer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 6:50pm
Now I am officially confused. My L59 is on a model C. I bought it like this. The triangle piece is in the inside of the flat bar, so when I raise the lift, the triangle hits the starter.   What does the other end of that picture look like? Do they mount the same on a B or C, from the picture it looks like a B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 7:59pm
Well I am not confuse at all. I don't know enough about it to be confused. My wife bought me that tractor in  Oklahoma eight years ago as a wedding gift. I brought it up here along with her. Honeymoon was so long that I lost interest in the tractor. The tractor had a belly mower under it of the bush hog type. Single spindle with the kick back blades. The mower needs a new deck welded on the top. I keep thinking I should fix it up to mow the pastures rather than the L 59 mower I am repairing now.
It is jerry rigged  with a pipe going thru an other piece of pipe welded to a hunk of angle iron. I thought you wanted to see the actual shape of the tri angle part. A Woods manual should show how it should mount.
