No Spark
barnyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnyard Quote  Post ReplyReply Direct Link To This Post Topic: No Spark
    Posted: 09 Nov 2018 at 4:26pm
Just picked up B10 , tried to fire up. While setting points, seems rod which opens points moves very little. Is this normal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 7:57pm
As long as its opening the points the thickness of a match book its fine. Poor mans gauge, or .20 thousands with a gauge.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 10:56am
i had the same issue with one that i had, it looked liked it barely moved but it still produced a spark.
it's possible that the plunger is worn out.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 10:34am
clean and gap points make sure they open and close or replace,    check spark plug wire conector, if all is good there then pull the fly wheel and replace the coil and condessor
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 10:35am
make sure the kill wire is not shorted out some where
