185 lift arms stuck in up position |
Post Reply |
TimZ(TX)
Silver Level Access Joined: 12 Sep 2009 Location: Schulenburg, TX Points: 258 |
Posted: 20 Jul 2010 at 11:34am |
I've seen this post several times and can't remember the cure. Is it the traction boost valve that is stuck and if so what is the fix? The arms go down after the tractor is turned off. There is a whining sound from the spool when you speed the motor up. I will pay better attention from now on.
Tim
Skyhighballoon(MO)
Orange Level Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Tim - link to another post about this with a picture. HTH. Mike
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=8010&KW=booster+spool&PID=62468&title=180d-rear-lift-arms#62468 |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7379 |
Following Skyhigh's link, refer to the second picture where there is a bolt with 2 nuts - 1 is shiny. If you remove that bolt, there is a bushing in there that has rusted up. Take it out, clean it up, and coat it with anti seize, and you will be good for a long time. Problem solved.
TimZ(TX)
Thanks I'll get after it this weekend.
Edited by TimZ(TX) - 21 Jul 2010 at 9:50am |
Post Reply | |
