6060 ? |
Post Reply |
Jim in SE ND
Silver Level Joined: 19 Jun 2010 Points: 61 |
Posted: 19 Jul 2010 at 9:14pm |
Did the 6060 require the same update on the front of the crankshaft to help prevent the bearing failure that the 6080 had? thanks
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1553 |
Yes.
ScooterBuck
Bronze Level Joined: 19 Oct 2009 Points: 76 |
Does anyone have a picture of that update that they could post on this thread?
AllisFreak MN
Can't post pics but can tell you that it is a bracket bolted in front of the crank pulley. Appears to be bolted to the engine block in three places. The bracket has a grease fitting in the lower front. It holds the crank in position so when the PTO clutch is disengaged it does not put too much foreward pressure on the crankshaft, taking out the crank bearings. Apparently the 433T & 433I engines were not designed to be in a tractor with a clutch putting foreward pressure on the crank shaft as they did not have thrust bearings. They were meant to be in belt drive applications such as combines and dozers.
Post Reply | |
