2300 Disc: Repair Questions
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 2300 Disc: Repair Questions
    Posted: 04 Sep 2018 at 3:21pm
Two questions on the docket today:
1.) My disc has the older non grease-able bearing/flanges.  Can I simply drill and install a zerk into the flanges or is the old style bearing and sleeve (what appears to be the rubber mount pictured on page 15 of February 1975 publication) non-compatible to external greasing?  If not compatible of course I am looking at new flanges and bearings.
2.)  I will be replacing the front discs due to breakage and general wear.  Notched or smooth discs?  The disc will be mainly used for summer secondary tillage (after chisel plowing prior to alfalfa direct seeding), but could be occasionally used for cutting heavy trash in fall if I have an issue chisel plowing corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2018 at 3:47pm
Notched blades last probably 50% life of smooth blades. They also break easier if you have ROCKS.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2018 at 10:04pm
My vote is for smooth blades too!
They cut more!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 5:30pm
Thanks for the replys guys!
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2018 at 6:11pm
I don't think your old flanges and sleeve will work with a grease fitting. You will need new grease-able  flanges and grease-able bearings if you can find them in that size.
