Anyone built their own 3 point hitch for a wd45? |
Pippin5267
Joined: 16 Jul 2010 Location: Bristol, TN Points: 15 |
Topic: Anyone built their own 3 point hitch for a wd45?Posted: 16 Jul 2010 at 6:48am |
I was just wondering if anyone had built their own 3 point hitch for a wd45 or if there is a website that has a blueprint of how to build your own 3 point hitch. I am pretty good at fabricating and welding but I would like to have a design to look at rather than trying to guess my way through it. Any help would be appreciated. |
JohnThomas
Joined: 14 Sep 2009 Location: Traverse City Points: 332 |
Posted: 16 Jul 2010 at 6:56am |
Yes, I built one for my WD. Worked real well. I used the same pin the drawbar pulls from as the starting point. Cost a LOT less than ones on market. It was strong enuff to raise the front of the WD lifting/skidding heavy logs.
Life is short...Make haste to be kind
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 16 Jul 2010 at 7:12am |
I built this one for about 125.,work real well.
Sitesstables
Posted: 16 Jul 2010 at 8:41am |
Only issue I have with mine that we built is that is moves a good bit with in the snap coupler.. Will try to get some pics.. it is not fance but cheap and worls real well for everything I do with it.
Brian G. NY
Posted: 16 Jul 2010 at 11:05am |
Here's one a friend of mine made for his 45.
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 16 Jul 2010 at 11:59am |
tonystractors.com has them comercially availably for WD, WD-45
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 16 Jul 2010 at 12:01pm |
With three or more manufacturers of three point adapters, why spend effort on somthing you can't buy or raising a crop or a garden?
Gerald J. |
Gary (sw Wis.)
Silver Level Access
Joined: 12 Sep 2009 Location: S.W. Wis. Points: 219 |
Posted: 16 Jul 2010 at 12:10pm |
I built my own for my WD. I bought the arms and pins. The rest I built from scrap I hade around. It works great and I do not have to remove the drawbar, all for less the $90.00 two years ago.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Pippin5267
Posted: 17 Jul 2010 at 7:12am |
Thanks for all the replys! What is a good place to mount the lift arms under the tractor. Did you guys mount them on the drawbar somehow?
Gerald J, I would rather spend a little time and a little money to build something myself and take pride in it, than I would spend $400-800 for something on the market.
Thanks.
StanOhio
Joined: 11 Sep 2009 Location: Port Clinton,Oh Points: 139 |
Posted: 17 Jul 2010 at 7:40am |
Pippin, I made one for my D10. I looked on line at one and printed one with it mounted and one of all the parts. I took the mounted one and looked at tractor and took all my measurements and went from there. I bolted it to the drawbar. I think I used 2x2x1/4 angle iron and wielded 7/8 round threaded for a lock nut, or maybe I pinned it and afterwards thought I should have lock nut it. I don't think I had much more than an hour making it. I'm like you, I wasn't going to spend $400 on something I can make for $50 or less. I can put the money I saved towards a paint job or other parts. After market is after market, if you made it yourself or buy it, its still after market.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 17 Jul 2010 at 8:08am |
Locate and purchase a AC SC adapter and your done, then it can be used on other SCX tractors, retains value for re-sale. I have one I will sell. They are heavy, shipping is high $$.
BobHnwO
Posted: 17 Jul 2010 at 8:53am |
Not trying to make the guys mad that sell 3 point hitches,there is prolly only about 5 percent that would try to make their own hitch,I enjoy makin all kinds of stuff,always lookin for different ways to do things.
JohnThomas
Posted: 17 Jul 2010 at 4:41pm |
Pippen... As I mentioned...start at the front where the drawbar pulls from...it's about a 1 inch pin. That way you pulling from same place tractor was designed to pull from.
I used 3/8 x 3 x 3 angle irons and welded thickening pads on each end after I bend them a bit to fit the angle..that is the angle from abt 5 inches wide at the pin to abt 3-1/2 feet wide at the lift arms. Actually a really simple setup. |
Gary (sw Wis.)
Silver Level Access
Posted: 17 Jul 2010 at 5:38pm |
I used a 3" piece of angle Iron (1/2' thick) as a mount to the drawbar. I welded 3/4" flat plate on each end to mount the pins. I also welded a 1/2" plate in the middle of it and bolted it to the drawbar so as to be sure it would not pivot.
Hope this helps.
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 17 Jul 2010 at 9:52pm |
gary i agree you did the same thing i did on one of my 45 diesels.the anti pivot block is definetly a must
Pippin5267
Posted: 18 Jul 2010 at 7:28pm |
Thanks everyone for all the info. I actually found a really good parts diagram on worksaver.com that I'm gonna use. Probably wont copy the hitch entirely but I think I will build the main frame of the hitch the same as they did. Went to TSC today and bought my lift arms. I will try and post a picture of it when I get done.
BearcatnorthMN
Joined: 23 Sep 2009 Location: Baudette, MN Points: 123 |
Posted: 19 Jul 2010 at 8:30pm |
On my WD I just bolted a short piece of sturdy chain from the snap coupler arms down to the lift arms. Works great. Can adjust it too, just lenghten or shorten the chains. For some of my attachments I even use a chain for the top 3rd link, or a power pole bolt with the eyebolt ends. I will eventually put something more solid but the chain thing works and is quick to hook up......
BearcatnorthMN
Posted: 19 Jul 2010 at 8:31pm |
I of course used bolts to connect the chains to the lift arms.
John Henry
Joined: 11 Apr 2025 Location: Pennsylvania Points: 1 |
Posted: 11 Apr 2025 at 6:14pm |
Hey, Pippin, this is Paul in Pennsylvania. Wondering if you did get around to developing a good three-point hitch for your WD-45? I have just acquired my WD-45 and brush hog but I'm looking for tried and proven ways of hitching this brush hog. Thank you for answering!
Paul
Edited by John Henry - 11 Apr 2025 at 6:15pm |
Jim.ME
Posted: 11 Apr 2025 at 6:25pm |
Welcome to the forums,
Pippin shows as last visiting the site in late February of 2011. Someone else may be along with info on a WD45 and the three point hitch they have on it.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88586 |
Posted: 11 Apr 2025 at 8:56pm |
John... just to double check.. You have the rock shaft and upper arms on the tractor and that works ? Your wanting to install lower arms with or without the drawbar.. to attach to the mower...( do you have a drawbar and frame ?) Will you need the drawbar after that ? Will the mower basically stay on the tractor full time ?
![]() Edited by steve(ill) - 11 Apr 2025 at 8:57pm |
steve(ill)
Posted: 11 Apr 2025 at 9:00pm |
here is the basic idea.........
if you have a snap coupler and dont need a drawbar.. here is another version.. ![]() Edited by steve(ill) - 11 Apr 2025 at 9:08pm |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3101 |
Posted: 12 Apr 2025 at 1:16am |
With a WD45 think I'd just be looking for a pull type brush hog,AC built some really good ones BTW and some are still around.Think I have 4 around here.
