Transmission bearing for a B |
Kiwi
Joined: 23 Jan 2018 Location: New zealand Points: 391 |
Topic: Transmission bearing for a BPosted: 31 Jul 2018 at 3:32am |
Hi all I need to replace the transmission main shaft bearing the needle roller bearing at the back on a Allis B .can anyone tell me the bearing number or the measurements of this bearing.the tractor has a 1-3/8 pto fitted.
Ed&Sherry
Joined: 08 May 2010 Location: Owego, NY Points: 234 |
Posted: 31 Jul 2018 at 6:19am |
the last transmission main shaft bearing is called a roller assy 211700
Kiwi
Posted: 01 Aug 2018 at 3:18am |
Thanks Ed the bearing number you gave me has a measurement of 40mm OD but the bearing in my English B is 47mm OD are the EB’s differen to the USA B
K-Mo
Joined: 09 Feb 2013 Location: Atlantic, IA Points: 91 |
Posted: 01 Aug 2018 at 5:37am |
AGCO Bearing Xref says the 70211700 is a NU303ECP. K-Mo
KOG
Posted: 10 Jun 2022 at 2:41pm |
Just ordered one for my 1939, about $45
SWPennTom
Posted: 27 Oct 2025 at 6:27pm |
I'm changing out the trans main shaft on my '49 A/C model C. The main shaft splines have been destroyed, so I am also replacing the clutch shaft and sleeve with good used.
The issue I have is about the rear bearing assy on the trans main shaft ( part no.s 211699 and 211700 ). Is the bearing race a press fit or should the race spin freely, being retained the snap ring? On the replacement used shaft I got, the race appears to be a press fit. It's frozen on the end of the shaft, no evidence of corrosion locking it on. The shaft I'm removing from my C, the race spins freely, the snap ring holds it in place. Don't know if I should just go with it or cut the race off the 'new' main shaft, and replace it with my existing race.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90653 |
Thanks(1)
Posted: 27 Oct 2025 at 6:43pm |
if you are talking about the inner race of a bearing, the race does NOT spin on the shaft.. the rollers spin on the RACE.. Inner and outer races should not "spin" as that would cause wear to the shaft or housing..
this is what i used years ago... Top shaft
bearing rear end in PTO housing
Bearing FAG roller, inner race on trans shaft NU303 1.850 x .669 ID (of inner race) x.551 wide |
SWPennTom
Posted: 27 Oct 2025 at 9:48pm |
Thanks for that info! Saved me from making it worse. The replacement trans main shaft is from a model C that is older, very minimal wear, not like mine at all.
I did not expect to see this when I took the torque tube off. The shape of the wear pattern makes me think that it was jamming the clutch shaft into the back of the crank when the tractor was under load. ![]() |
