need cessana pressure valve spring
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: need cessana pressure valve spring
    Posted: 05 Jul 2018 at 8:53am
I found my issue the first place i looked. I'll assume Dad cranked pressure high(as on everything) and stressed spring. I put 3 washers in to shim it and everything works fine. I would like to get the correct spring.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 8:57am
you might specify what this is for and if it is industrial you might be able to find a part number in Minnpar parts books.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 4:49pm
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:23am
Check with a local Hydraulics shop, Eaton and Cessna are a combined company now, may be something still available.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 11:57am
I have a extra valve block assembly for an I-600 which I think has the same Cessna control valve that I could rob the spring out of for you. just need to know what section it came out of.
Corey743 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 12:47pm
If you can get the dimensions of the spring you should be able to find a machine shop near you that could wind you a new one.
This page was generated in 0.107 seconds.
