7000 series cab roof
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series cab roof
    Posted: 23 Jun 2018 at 7:38pm
Seems I either have a hose leak or a bad heater core in my 7010. Any surprises to look out for before I pop the top?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 8:55pm
Might get ready to find a massive mouse nest. I just did about same except my AC drip lines had come loose. If so, a trash bag, vacuum, & air compressor nozzle come in handy, after you pop the top.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 9:39pm
A helper would be good to have, couple tall step ladders....
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 10:25pm
Waspsuses
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 12:15am
there will also be a lot of dust/dirt up there. while you have the top off, run a wire down thru the drain hoses for the ac condenser, they will usually be plugged with dirt. will hafta take the one way valves off the bottom of the hoses. (then leave them off).
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 2:39pm
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 2:42pm
Now what are you going to do??Unhappy
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 3:03pm
Did it. Mama's gone and been gone. So clean out time. I already got a wren in my gas grill
making it a maturity ward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 3:57pm
Wink  Was it as easy to do as you hoped(roof removal) and did you find the issue?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 4:41pm
Dead simple. Two man job to get it on the ground. Unfortunately it was the heater core leaking . But I did determine that the fan works and the ac switch is new. Check out the compressor clutch and if I get lucky there I may have A/C soonish.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 8:50pm
Is it worth cutting some insulation board
to fill the voids in the roof?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 9:00pm
I would consider something like dyno-mat on the roof top, maybe cab roof also, then look for some kind of insulation..
I think it would help quiet the cab and help with heat and air conditioning
I have searched e-bay and found all kinds,
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 9:38am
All kinds,yes. Summit has 124 listings all sizes shapes and thicknesses. Plus I need an interior cab kit. May have to hold off a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 9:49am
I put new cab kit in my 7060, restuffed a lot foam in the dash area, new floormat, sure made it nice, cab is quiet,even with a straight pipe, and the AC works good,,
If I take the top off again, I will put something up there....
Edited by Michael V (NM) - 26 Jun 2018 at 9:50am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 10:12am
Mine came with a new floor mat not installed. I figure I'll knock out all I can ac,heat,radio and so on while I'm at it and be done. The rest of the tractors to nice not to do the cab also. Plus all the components all there just get them working.
Edited by exSW - 26 Jun 2018 at 10:14am
