99 Dodge 3500 ac only works on high?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 99 Dodge 3500 ac only works on high?????
    Posted: 17 Jun 2018 at 12:35pm
Got a 99 Dodge 3500 and the ac only works on the high fan blower setting ? Anyone know what could be going on here ? Smells like something is getting hot too, thanks
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 12:57pm
I had one that the fan resistor for the switch was bad and only worked on high for both heat and air. It didn't smell , and was a different dodge. The resistor was the coil type and in the fans air stream.   HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 1:44pm
not familiar with the Dodge, but FORD and CHEVY both use a resistor pack to vary voltage  for 1-2-3-4 speed fan motor. To keep it cool, the resistor pack is normally stuck inside the duct air flow.. On a lot of trucks, you lay on the passenger floor and look up under the glove box and there is a small " block" with  a 4 pine wire harness going to it.. It bolts to the underside of the air duct and the resistors stick into the air flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 1:47pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 10:48pm
One fix is haul off and hit the dash with your fist as hard as you can. Fixed my daughters.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 11:53pm
Oh Boy Steve, I had to go and look at that thread you posted.  Now I'll be bugged by Ebay for the next week for all things Dodge!  My own fault!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 12:18am
yep….just replace the fan switch. the aqc will work the same on any blower speed
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 7:54am
I worked for dodge for 20 years I would say resister ,when they go out it will only blow on high so you don't lose all speeds ,high does not use resister,
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:38pm
yes, the resistor,  On my Grand caravan it was easy to get at and fix.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 5:17am
change blower motor also, motor going bad will only run on high and burn up resister
plug on motor may be melting, mine melted off
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 11:16am
Sure enough, I'm getting ad's for Dodge heater control switchs.... aargg!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 6:08pm
Yeah im with you John, everything is blowing up like that , ggggrrrrrrr, thanks guys
