wd carb help please
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: wd carb help please
    Posted: 12 Jun 2018 at 9:05pm
Need a little help. Not a great carb man. Bought a wd with a gleaner z in it. wouldn't idle so I changed some things and got it to idle. In the process of taking apart several times it will now idle but when I give it gas it kicks the governor in and out in and out repeatedly. If I fool with the load adjustment it will smooth out but as soon as move throttle does the same thing again. Throttle rod may be an 1/8 to a 1/4 inch short. Could it be this or in the load adjustment needle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 7:13am
Governor link rod too short will make the governor more jumpy, so it could be your problem, but not guaranteed to be your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 8:25am
thanks dr allis that's what I was thinking they had tried to modify it for speed pulling and made it a little shorter.
