Is this work around ok to do
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Is this work around ok to do
    Posted: 09 Jun 2018 at 11:25pm
Today I went to get my D-17 out of storage. Charged the battery and then went to start her. Nothing. Then I got a spark from the negative cable. So, I didn't have a new cable as it is showing it's age. So, I found 3 copper washers, inserted them in the cable gap. Then retightened up and it started just fine. Is this a safety concern or is it ok to do this for a couple weeks until I can get a new cable?
Thanks in advance for any thoughts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 11:56pm
sounds like it works o-k, i'd still replace the cable as soon as you can tho!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 11:58pm
I've taken a small nail or screw and loosened the clamp, put the nail or screw in the opening then tightened it back up before. worked for worn out clamps. until I could replace them
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 6:06am
OK for now, but get TWO cables ( + and - ) when you're in town !
