D15 II Lift arm?
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Lift arm?
    Posted: 08 Jun 2018 at 1:22pm
Whats the easiest way to remove the upper lift arm on a factory 3pt D15?  I have a brand new old stock replacement but cant get the old one off that's been there since 1964. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 2:00pm
You will have to slit/cut it on the thin side and use some heat to spread it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 9:56pm
Could remove rear housing, drive pin out of center coupler, remove shaft and arm, then press arm off shaft.    MACK
This page was generated in 0.041 seconds.
