WD45 power steering?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Topic: WD45 power steering?
    Posted: 08 Jun 2018 at 8:20am
Anybody have a template for the WD45 power steering pump mount. what I have is pretty wrong. I see in the agco parts book it looks like the pump is located on the left above the generator and a idler pulley on the right. even a picture of it installed would help. I have a cobbled setup that the pump is directly above the waterpump and interfears with the radiator hose.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 2:54pm
I can text you some pictures of a gas 45, however the hood is on and may not do well enough for a template. Kevin
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 5:03pm
I think I have a spare mounting plate in a pile in the garage, if i can find it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 5:59pm
A mounting plate would be awesome if you could find it. Let me know what you want for it. I still taking it apart to put the pulley on the crank. Pictures could be sent just PM me and I'll sent my email
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 8:57pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 9:16pm
I have one I would sell
email me and I will send pictures
lselkriver@gmail.com
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 10:28pm
down sized this image
Edited by JC(WI) - 09 Jun 2018 at 11:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 10:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 10:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 10:33pm
 Also have pages 5 and 6 for WD45DIESEL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 8:58am
The picture helped and I printed the SB pages and added to my service manual. these should help a lot I have a charlynn unit and a pump that looks a lot like the correct one. I've contacted Lon about the mount he'll sell so hopefully Ill have power steering fairly soon. as long as this works I'll put the loader back on this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 12:40pm
Good you found one. I looked thru the shop twice and can't find the one I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2018 at 2:19pm
I'm making one. My charlynn pump is to bulky to fit in the stock AC pump location. Other projects have taken priority so it's good I've got shop space. At the rate I'm going it'll be a couple weeks. So far I've tore it apart and got the crank pulley changed. Right no getting the steering shaft apart is holding me up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 11:51pm
Finally got the power steering install completed man dose that work nice. I still need to bend the throttle shaft. But I wired it so it won't go above idle. Filled it up and tried it it spins with one finger
