electric chain saw
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: electric chain saw
    Posted: 06 Jun 2018 at 11:14am
I have a couple of electric 16" Remington chain saws, 1 manual chain oiler the other auto oiler.  Both manuals say not to use bar and chain oil, but to use 30 weight motor oil. This seams strange to me. Why not bar oil ?
Dusty
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 11:20am
My guess would be due to the viscosity.  Bar oil is very thick like gear oil, at least 80 or 90 weight, probably even higher.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 11:25am
I love my little Remington..................
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 12:09pm
Grayray is correct. regular bar oil is to thick for them.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 7:14pm
Could be the chain don't travel near as fast? I've never looked at the RPM on an electric. I've used anything slick on my old gear drive chain. Boogers would probably work.
Edited by Walker - 06 Jun 2018 at 7:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 9:25pm
30 wt non detergent works best in all my saws, electric,gas, and battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 11:06pm
The bad thing about motor oil is it don't have the tackafiers to keep it from flying off the chain. I've heard of using peanut and veggie oil in environmentally sensitive areas. Like I said anything that felt slick used to go in my old David Bradley.
Edited by Walker - 06 Jun 2018 at 11:10pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 6:28am
i think Walker is hitting on it.  Just might be the chain speed.
On my gassers, i would never use anything cept the bar and chain oil.  It is tacky and does a lot better lube job.  My experience at "experimenting" with motor oil on the gassers is that it slings off readily and the chain makes more noise and has to be tightened up a lot due to wear.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:14am
We got a Makita electric chainsaw for work in the barn last December.  Calls for regular bar oil and does fine with it.  Chain speed is equivalent to a typical gas chainsaw, it's really a nice unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:36am
Shameless,
How does the speed on your battery saw compare with your electric saw?
I have a 20 volt pole saw and it runs much slower than my 120 volt one.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:40am
I shoulda specified, our Makita is 120V.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:45am
The old chraftsman saw in the shop uses bar and chain oil. The wife's alligator saw has SAE 30 on the oil cap so I just use what the label calls for. Both are old and have held up well. The alligator saw has a 6" blade and seams to run slower than the chainsaw.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 10:40am
When I was in the logging business in the late '70's, there was an additive sold at saw shops to add to regular motor oil that made it work better.  Haven't seen it in years and don't remember the name.  Would something like STP added to motor oil do the same thing?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:18pm
I'm almost certain in the gear drive era motor oil was called for both chain and mix but it wasn't like they had much to choose from back then either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:33pm
If you look at the right place, chain oil does come in two grades. Winter and summer, winter grade thinned a bit with whatever may just work in your electric.
Edited by Walker - 07 Jun 2018 at 8:34pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:34pm
I enjoyed my Remington electric saw. Son ran it with too small of an extension cord, motor went up in smoke. I then bought a Remington Versa Saw. A large plastic gear drives the chain. Not a great idea. I have replaced 1 and have a spare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 9:05pm
Dusty....my pole saw also runs slower than both my electric and either/both of the battery saws. both my battery saws are B&D as is my pole saw, the instruction manuels call for non detergent 30 wt for the chains. I have always used the 30 wt non detergent in my gas saws too in summer. I cut back to 20 wt in winter on the gassers. I was watching a chain saw carver one day at the fair. I asked him what he used for bar oil since I would have thought the oil may stain the wood. he said he used a mixture of what ever he had sitting around. poured it all together and shook it. he said the regular bar oil is to thick and would sometimes stain the wood he was cutting.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 11:30pm
I was once told by an older gentleman that chain oil and gas mix oil are just 20w oil, and there ain't no reason to buy the oils that are supposedly "special".  That's what I have always used and have not had any negative reactions from either.
Edited by john(MI) - 07 Jun 2018 at 11:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 12:59pm
I found this doing a search;
Chainsaw manufacturers make bar oils matched to the air temperature and the saw in which it is operated. Although they don't disclose the weight of their oil, the University of Missouri Extension recommends in lieu of using a bar oil, select SAE 30 weight oil in summer and SAE 10 in winter.
A gentleman I knew, who was a 30
year Vocational Small Engine Tech., said that you could use 30w oil and add STP.  1/3 STP to 2/3 oil.  I've used it that way for YEARS....  I've never worried about bar wear either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2018 at 8:10pm
With motor oil at 4 bucks and over a quart and chain oil at 4 and under a gallon I think I know which direction I'm going.
hdalepalmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdalepalmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 12:39pm
A Old-timer told me to use canola oil its cleaner easy to find and cheap at the dollar stores
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 8:27pm
I don't even know what a canola is but I'm thinking that if you didn't watch on the veggie oil and some of the others after a couple months of using it in summer it would be like carrying around a dead animal with you in the woods. Overall I'd say that they don't call chain and bar oil chain and bar oil for nothing.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 8:55am
In order for the canola oil (from rapeseed plant) to smell like rotten flesh, you would have to change the polymuric valance viscosity of the canola oils polypeptite bonds on the Phosphital chains. This is not the easiest to do but is possible. Until then your chainsaw would only attract squirrels, and rodents.   Geek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 4:20pm
chas, did I ever learn something today.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2018 at 5:14pm
One more reason to use bar and chain oil, then ya don't have to learn all them hard to say words.
