220 brakes
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: 220 brakes
    Posted: 25 May 2018 at 4:04am
Yesterday my dad was working the 220 with a vertical tillage tool. He did close to 40 acres. When the right brake started to get really Hot. The tractor doesn't pull to the right at all and it still actuate fine. I loosened the pedal adjustment after it cooled down. Took it down the road a bit and it was warming up again. I put relined disc on a couple years ago new springs and balls. I chisel plowed last fall no problem. I don't have time to tear it apart now. What could be going on? I hope it didn't burn up the shaft seal? Has anyone had this happen? Thanks
Edited by fastallis - 25 May 2018 at 6:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 3:33pm
Did you grease or anti-seize the ball pockets and the machined rub pads on the O.D. of the plates ??????
This page was generated in 0.202 seconds.
