Triple Remotes?
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: Triple Remotes?
    Posted: 10 Jul 2010 at 10:25pm
Did AC offer factory triple remotes on any tractor?  Which ones?
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 10:31pm
I think that all of the 7000 and 8000 series were available with them, and I imagine the 6000 series too, but I'm not sure.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 7:35am
We've got triples on a 7060 and a 7580, they had the places for them on most of the 7000 tractors, it was just an option.  It looks like you could add on another unit to a set that only has a pair fairly easily, but Ive never done it.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:51am
Don't know if "original" (looked right tho) but had a D19D W/3 remotes; 2 were for a double acting cyl, 1 for a single acting cyl. 3 levers on the valve spool; 1 for the double acting remotes, 1 for the single acting remote, and one for the rear lift arm rams.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:56am
We added a 3rd remote to our 7020 a few years ago. Got the valve and cable from a salvage tractor. Made the lever. About 3 hrs and we had it completed..
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:24am
I'm not positive, but I think the D21's that didn't have 3 point, had the third spool used for another set of remotes.  The rear plate under the fuel tank has 6 holes for remotes in my D21, but it only has 2 sets since it has the 3 point on it.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:05am
I don't remember the setup but we pulled 3 implements at one time, all with two way cylinders, behind the One-Ninety. 10' Disk, 11' Field Cultivator and Cultimulcher.  Pa found a way to afford the tractor but not new implements, so we simply tagged up wd45/d17 implements we already had and did multiple operations in a single pass. I'm sure they all operated from the Counsel Control Center- what a great tractor for the time.
