Another First Ona C
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Another First Ona C
    Posted: 27 Apr 2018 at 2:04pm
I went to start the C with the Woods under it. No Spark. I had rebuilt the magneto last summer. Checking it out with the meter I said AH shorted out condenser. Found a new condenser in the shed and started to change it. When I loosened the screw where it attaches to the points and coil I see the condenser had a big forked terminal and it looked it was close to the base. I slid it out and decided to check it before I remover the condenser. It checked good. I turned it over and after tightening it I bent the long end of the terminal up and put the cover back on. It then started like I had turned on the switch on an electric motor.
The screw was tight and the fork was against a strip of tape that it must have wore through. Dang little details missed that pop up afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 6:58pm
BTDT, I usually snip the ends back a little, they often short out, that way...
10-E Chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10-E Chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 7:42pm
Wel, at least you figured it out before tearing it all completely apart
Grease is always cheaper than bearings!!!
