06 Silverado troubles
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Topic: 06 Silverado troubles
    Posted: 24 Apr 2018 at 7:24am
I've got an 06 Silverado that doesn't want to shift into passing gear. It up shifts through the gears just find but when I try to go to passing gear it vibrates and doesn't want to shift. If I mash the pedal down further it will shift. I had the trans serviced thinking maybe a clogged filter but no help there. I was told by the mechanic it might be the throttle position sensor but he says the scanner should it to be good. Anybody got a suggestion?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:51am
How is hard acceleration from a stop?  Plenty of power and upshifts just fine?  Can you manually downshift the transmission OK?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 10:05am
Take the mat out from under the pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 10:33am
Start and upshift is fine. Haven't tried manual shifting. The problem doesn't start until things get warmed up. I'm pretty sure its a sensor somewhere that's about ready to go and throttle position sensor makes sense it just didn't show anything on the scanner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 10:48am
I made some assumptions on engine/model.  These are from Rockauto.com
Edited by Stan IL&TN - 24 Apr 2018 at 10:49am
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 3:24pm
Those were some pretty good assumptions there Stan
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 5:28pm
Make sure they serviced the trans with the right kind of fluid, that should take the synthetic global fluid, assuming it was fine before the service.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 5:32pm
It was acting up before. I read that it could be caused by a slight misfire that's not enough of a misfire to turn the light on. I'm sure it could use plugs, wires, etc so I'm going to go that route and see how it does then
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 10:29pm
Sounds like the valve body is sticking.
