WD45 cam brgs |
Post Reply ![]() |
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Jul 2010 at 12:08am |
Do cam brgs need honed to fit after installation or are they considered precision these days?Thirty yrs ago it seems I remember people saying new cam brgs needed honed.I don't remember what applications did or didn't need it.I gotta pull the crank out of my 45 and I wondered about putting cam brgs in it while there.It was overhauled 30yrs ago and didn't get them then.Oil guage runs on "N" of normal and I've heard guys on here say loose cam brgs on WD's and 45's will cut oil pressure.I've also heard that there is a difference in those guages and all I remember is we put a new one on when it was overhauled.I suspect I could have some rods flaking because I've found babbit in the drain plug over the years.It got alot of heavy use/abuse the first15yrs but now sees planter and bush hog duty.I think the guage used to read higher but never paid that much attention.Get on and go! Reason the crank needs attention is pulley has ran loose a long time and necked the crank and wollowed the pulley.Going to have machine shop true crank nose and bore/sleeve pulley to fit.Edited by Steve M C/IL - 10 Jul 2010 at 12:09am |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
I put new ones in my WC and didn't have to do anything to them.
That sounds encourageing Charlie.Where'd you get you brgs from.
ORANGE FARM ![]() Bronze Level ![]() Joined: 01 Jun 2010 Points: 43 |
IF YOU GOT AFTER MARKET ONE.THEY DON'T WORK. |
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
My opinion is anytime something has a interference fit meaning the id of the hole is smaller than the od of the bearing it needs to be honed for it could be distorted.
The problem is the engine will only be partially dissasembled hanging on an engine stand at my place and I have no means of honing cam brgs.Not as simple as hauling a bare block to someone to hone. For some homemade,jury rigged way of increasing clearance,I might,as well leave well enough alone.Could end up with looser fit than before.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
I recently ordered cam bearings for my D17D from Sandy Lake Imp and Betty told me they have had issues with some aftermarket suppliers of cam bearings fitting the block, but then not fitting the cam without honing. I would call Sandy Lake and have them get them for you. Betty seemed to know which ones to get that would be ready to go once installed.
dont worry if the cams bearing journal will go into the bearings id . either the cam journal or bearing will hone itself to match the shape of the other. hopefuly the oil filter will catch the metal pieces.
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25085 |
I gotta go with Mitch on this one, I sure wouldn't go to all that time and expense and cut a corner like that. It might work.......but then again
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
I can't decide if Mitch is serious in light of his previous post and I don't quite get my friend Lou's advise on corner cutting.I've been married 30 yrs and tell my wife to just say what she means.I can't read between the lines anymore.My problem,I know,but that's how it is.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
I agree with Lou now would bethe time to do complete bottom end specially scince you know history cam bushings are only about $30 or so.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3583 |
I have only done three tractor motors, a JD, Ford 8N, and am doing a D 15 II allis now. The ford did not have cam bushings. My thoughts on a tractor is that if the cam slides in the new bushings and you can give her a spin and there is no drag then why line bore? I know there are pie in the sky answere, but I can't see tsking off some bushing and making the hole bigger when you can let mother nature work it down some and get some mileage out of doing it that way.
Steve,
My bearings came in a Tisco engine kit. I have been a machinist since the early 70's so I think I know what will work. I used the proper tool to install the bearings and the cam fit like a glove. If I remember right, you have to line up the oil hole in the block with the new bearing. |
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
I have a cam bearing tool to remove and install bearing. Like Charlie I have rebuild lots of WD's and have found all kinds of shims under the relief spring on them, Thinks like washers, nuts, and one time I found a rock in there all because the engine needed cam bearing replaced.
Don
I forgot about the relief spring Don. I pulled a stack of washers out of mine. It has god oil pressure now without shimming the relief spring. I don't know what is after market,but if you take a hammer and a punch to the cam bearings they won't work.
Thanks Charlie I now have a pic in my head of someone with a 8 lb hammer and a big poor word choice punch beating the heck out of cam bearings now! LMAO
Don
I'm starting to catch on,sorta.I was figuring on the squeeze methed VS the BFH. I can make a tool to do that but I think my cousin(former AC mechanic) already has one.Are you guys saying there is supposed to be ONLY the spring in the relief? No shims?Haven't even looked at that yet.I&T manuals suck.I have the WD section from local dealer service manual from the 50's which is more helpful.My dad knew all this from memory/experience but he's been gone since 2000.
Steve, they may have been shimmed but mine had 3 lock washers jammed in it. I didn't consider them as shims.
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
i dont know where you people are HONING a babbit metal bearing,first of all you will never ever get all the grit out of the bearing surface.why not do the job RIGHT with the aid of a micrometer and the properly adjusted reamer?a compitent machine shop can do this and it will not cost you an arm and a leg.i have overhauled several 45 gas and diesel engines and did everyone that way.i am glad i am not flying some of those repairs...
Post Reply ![]() |
