WD won't start
ford8nwd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ford8nwd Quote  Post ReplyReply Direct Link To This Post Topic: WD won't start
    Posted: 09 Jul 2010 at 5:21pm
 My WD has been running pretty good, but I was doing some raking today and she wouldn't restart after shutting it down to clear a clog in the rake. Turned over real, real slow, and wouldn't start. The battery is up, tuned up recently, popped off good when I started her up before raking. Any ideas?
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 5:39pm
I'd say look for a burnt wire or a bad connection somewhere in the ignition,,sounds to me like that'd be the place to start,,,,,bad ground Possably?
www.allischalmersmuseum.com
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 6:26pm
6 or 12 volt?Battery cable connections may need cleaned,loosen the bolt holdin the starter motor and retighten,starter bushings worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ford8nwd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 6:52pm
Btery connections are all clean and tight. Just had the starter rebuilt.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 7:12pm
Check your water level. Also check your oil. Make sure you don't have one where the other should be. May want to pull the plugs and see if any water got in there. May have blown a head gasket. I hope not, but it never hurts to check. Pretty easy to rule it out. If it still turns over really slow, you may want to pull the spark plugs and put the hand crank on. See if it still has resistance with the clutch disengaged. I hope not, but it may have spun a bearing. Eliminate these, and the rest of the troubleshooting won't make you feel so bad. Good luck.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 7:48pm
  MAG.  or dist. Ign. ?        on a mag. ign. can you here the impuls snap if not could be the prob.  ifit was hot when you shut it off? did it start when it cooled? could be the coil. disconect the kill wire at the mag. could be shorting out somewere.  on a dist ing. check with a test lite for power at the coil both in & out check inside the dist. points burnt? or closed up check for spark at the coil wire . if 12 volt put a ba list restore  before the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 8:01pm
   I  fog to say put load test on the batt. 12 volt batts. drop dead rite now. 6 v0lts slow down then die
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 8:13pm
Are you letting your tractor idle a few minutes before shut down?  If you don't temps can spike and really tighten things upon shutdown.   Just like an old work horse they need to cool down when lathered up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 8:26pm
Along with all the other things mentioned, your timing could be a tad off if it starts hard warm.The hard cranking could be sludge build up around the outside of the cylinder sleeves as Dave E. mentioned the other day. The build up settles around the bottom of the sleeves restricting cooling of the cylinders. When the engine is shut down the cylinders close up from excessive heat. Good advice to let her cool down a bit.
Edited by CTuckerNWIL - 09 Jul 2010 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ford8nwd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 6:32am
Thanks, Guys
I'll let 'er cool down before shutting off, that makes sense.
