County line carry all for Allis Chalmers CA? |
Post Reply ![]() |
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1172 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Apr 2018 at 4:01pm |
Will this brand work for a 1953 model CA? I'm looking at using this for cleaning up some hay after I mount it to the rear of my CA I'm going to fabricate some Forks for picking up hay it is a narrow front end and I do not want to fabricate a front end loader on it with having to make it a wide front end so it's more stable
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24730 |
You should post a link to which one,I saw one at TSC and it's a 3pt unit and $369 !. My CA was snap coupler.
Now I made my own for 'Troy', my first D-14. Cost maybe $30 for some of the steel. It was easy to build and has hauled 1000# logs on it ! I used 42" forklift forks and added a 2" receiver so could tow any kind of trailer. I got rid of the loader as the carryall was far easier to use ! |
It's the yellow model that's 149$
Good reviews, I'm just unsure if it will work with a CA type 3. Hitch? |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88224 |
yes, that will fit a CA with a 3 point... The pins are category 1 and your CA should be category 2.. So the pins MIGHT be 1/4 inch smaller in diameter and have some slop.. You can use it that way, or buy bigger pins and screw them on... but will work the way it is.
Thanks,
Now I need to buy/ weld and cut to create a pitch fork type look with some more angle iron( kinda like a pitch fork on steroids is what I'm picturing) |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54287 |
OR just spend an extra 4-5 bucks, on cat 1 to 2 bushings... ![]() |
Post Reply ![]() |
