Hooking plow to a B
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Hooking plow to a B
    Posted: 04 Apr 2018 at 9:06pm
I know this question has been asked before. A guy at work just acquired his Dad's B and it has two turning plows with it. He said he couldn't figure out how they hooked up so he asked me if I knew. I said I didn't but I'd try to find out. Any pics or info would be appreciated.
He is supposed to send me some pics of his plows and tractor. I will post them when I get them, that may help. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 9:20pm
probably has a PIN on a cross bar below the  transmission... then the Rock Shaft lift arms in the back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 9:26pm
setting under the motor and looking backward, the silver pin attaches the beam to a bracket that is hinged on each final drive case... most setups have a lever attached to the bracket so you can raise and lower the front of the beam from setting in the seat... or you can have a solid mount so it will not raise and lower.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 7:32am
I just bought a set of plows and mounts from a C. I want to use it on my B. The crossbeam that mounts between the final drives is too long. I'm looking for the correct beam for a B, willing to purchase, or trade if someone can use it. Thanks!
