cracked block or head gasket?
young582 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote young582 Quote  Post ReplyReply Direct Link To This Post Topic: cracked block or head gasket?
    Posted: 07 Jul 2010 at 5:04pm
just bought a 1948 model C. coolant leaks into the oil. whats the odds of the block being cracked. he said when he it started to happen when he was driving it and he parked it. didn't drive it since. i still runs fine and he gave me a head gasket
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:10pm
It may not be either one. The first thing to check is the "freeze" core plugs in the top of the head. Pull the rocker cover off and have a look. It could also be an oring on a sleeve leaking. A leaking core plug is pretty cheap and easy fix.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:10pm
my B had two problems show up at same time.  Rust thru freeze plugs in the head and three leaking O rings on the liners.  Freeze plug is easy repair, o-rings... not so easy
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:13pm
As they said, why guess? Pull the valve cover and pan and find the leak then fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote young582 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:15pm
thanks he gave me a new head gasket i don't know if he knew thats what was wrong or if he was guessing. i still need to get some degreaser and degrease the engine because its covered and i mean covered  in a bunch of grease oil and bullsh*t :x
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:16pm
I was gonna say also, don't run the engine with coolant in the oil. Just kind of figured that was a given.
Post Options Post Options   Thanks (0) Thanks(0)   Quote young582 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 5:22pm
im going to school for diesel technology. im just trying to get some ideas on what you guys think. i changed the oil and started it to at least make sure it ran. and it ran. so its all good.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 10:29pm
If I was a bettin'man and it was running when he noticed the leak, I sure would pay $7 for a new valve cover gasket and check the core plugs on the top of the head. If they are bad, you get change from a $5 bill at NAPA, and a sweet deal on a tractor.
If that ain't the problem, then Rick, don't be so discouraging on those O rings. You drove it out on Sunday, didn't you??? And.... it inspired the Build-a-B !!!
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 6:46am
I am working on my 1938 WC Maintainer. the engine had good compression so I put oil in the engine and WATER in the radiator, next day I checked the oil dipstick, had gained about 2 inches, pulled the valve cover, it was a freeze plug. I went to NAPA, got 2 new plugs for .59 ea. OK now.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 10:09am
I just purchased a hi crop WD45. It was leaking water into oil. Found a cracked sleeve and all liner orings were leaking. Now it's got a new overhaul kit installed. No more leaks.
