3 point conversion kit
Steve R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Topic: 3 point conversion kit
    Posted: 12 Mar 2018 at 2:56pm
Does anyone have or know where to get a 3 point conversion kit for a WD?  I think I really need to put one on my tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 3:01pm
Several of the sponsors have these. and Stieners has them too.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:48pm
I made mine... used lift arms and links from Farm & Fleet...
Edited by DaveKamp - 12 Mar 2018 at 6:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:50pm
Here's where I put the top link... Usually, guys use a strap to the rockshaft...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:52pm
Here's how I fastened it:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:54pm
And here's the one I made for my D17:
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 8:13pm
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:15am
I have got several from Tony. They ship out of the Midwest and made by Cross. I really like those because you don`t loose the drawbar and the traction booster still works.
"Burgie"
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:49am
Biggest problem I've seen with the aftermarket 3pt hitches is there is little or no sway control.To be a useful hitch it needs a good easily adjustable sway control in my opinion.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 3:56pm
I have the wishbone one from Tony's tractors. It works well for me you do loose the drawbar with the wishbone but it's easy to remove or install. Just unlatch it and latch the drawbar back in. Since I have a matching pair of WD45s I leave the 3pt on one and the loader on the other. Once you put a 3pt implement on you don't want to keep switching it it nowhere as easy as a snap coupler implement. The sway control is very easy just cross the sway chains that you attach to the drawbar bail mount.my 3 point tractor goes from a snowblower in the winter to a disk in the spring and a mower in the summer. I couldn't use the draw bar with any of those installed anyway so I don't miss it. I do have a crossbar mounted one on the other tractor that would allow use of the drawbar but the lower lift arms are removed and hanging on the tractor shed wall if I ever need them. They tend to get in the way when not being used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 3:58pm
Be sure to buy extra health hazard insurance. Hitching up 3pt implements is bound to lead to pinched fingers and sprained backs. Along with a colorful new vocabulary
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 5:15pm
got a 3 pt if needed i will sell
