1150lb pro stock diesel class
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 1150lb pro stock diesel class
    Posted: 11 Mar 2018 at 1:16pm
watching a you tube video  any one know what they are useing for engines and drive train in those garen tractors? they look a lot meaner than my cub kadet with a twin kohler
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 1:34pm
I have heard a lot of small Kubota and Yanmar engines.  Nuts what they can pull out of them.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 9:17pm
what do you think the running gear is ?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:25pm
Kubota  or Yammar engines, Yammar has a direct injection so most are using it! cadet running gear with planetary rear axle added to cub rear end. Expensive units!!!!!!! We have a Kubota D-950 3 cylinder with small turbo, running 7000 rpm's we used in compact 4wd class years ago. Took it out and put in a Kubota G series gear drive GT  and pulled 1000-1100 lb class,but didn't do very well with it. Needed different gearing which cubs have everything available for them! Same old story! $$$$$$$$$$$ talks. Who ever spends most wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 11:26pm
its called cubic dollars     not cubic inches
