Series 1 gas d17 won't start |
Post Reply |
Bodin
Bronze Level Joined: 04 Mar 2018 Location: Mackenzie Points: 5 |
Posted: 04 Mar 2018 at 3:43pm |
Changed circulating heater and burped system would not start
Put in new battery had to boost got tractor running moved bale shut off for a week went to start again won't start Put in newseliniod and new starter tries to turn over then clicks Tried boosting get a grrr ere then click Help please |
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20398 |
Sounds like a dead battery. Sounds like new battery was never fully charged or there is something running the battery down when sitting. Disconnect the ground cable and charge battery on low charge for 24 hrs where it is warm--60 degrees F or more.
Bodin
Thank you will try
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18819 |
What's a circulating heater? Do you mean an external block heater?
Sounds like you have a bad battery or something is on and killing it. A possible drain. Is it a 6 or 12 volt system? Charge the battery up and DISCONNECT it from the tractor. Go back a week later and connect the cable you disconnected and try to start it. Does it turn over really nice or just go grrrr. If it's the grrrrr your battery is NO good. 6 volt batteries can sit on the shelf for so long that they are no good by the time someone gets around to buying it. Dr Allis, you're faster than me... Edited by Ted J - 04 Mar 2018 at 4:16pm |
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 616 |
Check your cables. I had a ground cable go bad. Put a new cable on and started right up.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5745 |
Or battery cable(s), or connector at one end or the other is bad. After you've tried cranking it, feel the connections from battery post all the way to solenoid, and positive post all the way to ground connection. If any are warm, you have too much resistance there.
(oops... Boss Man beat me to it)... so I'll second his motion.... Edited by DaveKamp - 04 Mar 2018 at 8:23pm |
Bodin
12 volt system
Bought me battery cables Will put on after work |
Bodin
Tried starting with boost
Just clickes |
DougS
Orange Level Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
A bad battery cable connection or a bad ground where the starter bolts to the block. Either would cause this.
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Do a voltage drop test. Start from the battery post and not the clamp. Pos probe on the post, neg probe at the clamp, read meter while trying to crank. Do the same thing all the way to the starter post. If you find more than .5 volt reading while cranking, you have unwanted resistance. If you never find much voltage drop on each cable in the circuit, and the battery is good and fully charged, time for starter rebuild.
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 959 |
Got another vehicle and person so as to pull start it? If it runs with a pull, that eliminates a lot of things.
Post Reply | |
